News & Announcements User Community Developer Community
Welcome to the RingCentral Community
Please note the community is currently under maintenance and is read-only.
Search
Make sure to review our Terms of Use and Community Guidelines.
Home » Developers
API call to Authorize from Postman
Tags: authentication, rest api
Sep 24, 2018 at 8:36am   •   14 replies  •  0 likes
sara
Hi all, I am trying to test the API call to Authorize RingCentral from Postman and I am receiving 'Could not complete oauth login' error. Attached the screen shot of my request.
Access Token URL: https://platform.devtest.ringcentral.com/restapi/oauth/token
Thanks!
answered on Sep 26, 2018 at 7:52pm
And you don't have to use Apex because we don't have official SDK for Apex.
You can use Javascript instead because there are ways for Apex to communicate with JavaScript.  Check this video from me: https://www.youtube.com/watch?v=bf_Z391G2cw&t=1182s
RingCentral has official SDK for JS https://github.com/ringcentral/ringcentral-js
Here is a community version maintained by me: https://github.com/tylerlong/ringcentral-js-concise
 1
answered on Sep 26, 2018 at 7:47pm
I highly recommend you to read https://github.com/ringcentral/ringcentral-ruby/blob/master/lib/ringcentral.rb
170 line of code and covers all the things you need to know. Way more direct than trying everything with Postman.
For example: for authorization part: https://github.com/ringcentral/ringcentral-ruby/blob/master/lib/ringcentral.rb#L154-L165
Before you get the token, use back authorization, otherwise use bearer authorization.
And in order to exchange code for token: https://github.com/ringcentral/ringcentral-ruby/blob/master/lib/ringcentral.rb#L49-L54
You can see that grant_type: 'authorization_code' and client_id & client_secret are not included in post body.(they are used in Basic authorization header instead)
 0
answered on Sep 26, 2018 at 6:12pm
If you want to jump to Apex sooner or later. Why not simply try some programming language instead of Postman?
As far as I can tell, Apex is similar to Java.  Here is how we do the authorization in Java: https://github.com/ringcentral/ringcentral-java/blob/master/src/main/java/com/ringcentral/RestClient...
 0
answered on Sep 26, 2018 at 7:41am
Another scenario
I am trying the following method of call using Apex
  1. Made an Authorize call to RC https://platform.devtest.ringcentral.com/restapi/oauth/authorize, Authorize call was successful and returned the 'code: XXXXXXXX' with response
  2. Used the Code: XXXXXXX with params to make a token call https://platform.devtest.ringcentral.com/restapi/oauth/token but getting 400 error.
Complete URL:
'https://platform.devtest.ringcentral.com/restapi/oauth/authorize?response_type=code&client_id=<CLIENT ID>&client_secret=<SECRET> &redirect_uri=<REDIRECT URI>&state=step2'
'https://platform.devtest.ringcentral.com/restapi/oauth/token?code=<AUTHIRIZE CODE FROM THE RESPONSE>&grant_type=password&client_id=<CLIENT ID>&client_secret=<SECRET> &redirect_uri=<REDIRECT URI>'
Any thoughts?
 0
answered on Sep 25, 2018 at 7:08pm
Hey Tyler, is it possible to make the authorize call automatically? or we need to login manually to authorize the request?
 0
answered on Sep 25, 2018 at 8:35am
It is working. I tried with another app in RingCentral and it is working now. Thanks for your help.
 0
answered on Sep 25, 2018 at 5:42am
I updated Postman and I am using same version. Now i am receiving the following error
{    "error" : "invalid_grant",    "error_description" : "Redirect URIs do not match",    "errors" : [ {      "errorCode" : "OAU-109",      "message" : "Redirect URIs do not match"    } ]
I gave redirect uri as https://www.getpostman.com/oauth2/callback
Can you tell me what would be the redirect URI? I never worked on OAuth2 API call and I am really confused.
 0
answered on Sep 25, 2018 at 12:56am
When you click the "Request Token" button, there will be a modal window. Isn't it the same for you?
By the way, I am using PostMan Version 6.3.0 (6.3.0)  for macOS
 0
answered on Sep 25, 2018 at 12:54am
Above works like a charm for me.
 0
answered on Sep 24, 2018 at 7:09pm
*and it will display 'GET NEW ACCESS TOKEN' button.
 0
answered on Sep 24, 2018 at 7:01pm
select OAuth 2.0 from the dropdown and it will display 'NEW ACCESS TOKEN'
 0
answered on Sep 24, 2018 at 6:43pm
I don't use postman very often and I don't even know how to bring up the UI as shown in your screenshot.
Could you please tell me how to reproduce the issue quickly?  Especially how can I bring up the "GET NEW ACCESS TOKEN" dialog?
 0
answered on Sep 24, 2018 at 6:06pm
Still same error.
 0
answered on Sep 24, 2018 at 5:46pm
Try to specify "Token Name"  as "access_token"
 0
A new Community is coming to RingCentral!
Posts are currently read-only as we transition into our new platform.
We thank you for your patience
during this downtime.
Try Workflow Builder
Did you know you can easily automate tasks like responding to SMS, team messages, and more? Plus it's included with RingCentral Video and RingEX plans!
Try RingCentral Workflow Builder
PRODUCTS
RingEX
Message
Video
Phone
OPEN ECOSYSTEM
Developer Platform
APIs
Integrated Apps
App Gallery
Developer support
Games and rewards
RESOURCES
Resource center
Blog
Product Releases
Accessibility
QUICK LINKS
App Download
RingCentral App login
Admin Portal Login
Contact Sales
© 1999-2024 RingCentral, Inc. All rights reserved. Legal Privacy Notice Site Map Contact Us
